Fluent New Version 6.3 Problem Help!!!!
Old   March 14, 2007, 16:50
Default Fluent New Version 6.3 Problem Help!!!!
phinix
Hello all,
I run fluent using 6.3 version, but when I tried to open the saved files using 6.2 version it does not work. The error message reported is as below, any suggestion will be appreciated.
====================== Error: Set_Thread_Variables: wta(real) Error Object: ((constant . 1) (profile "" ""))
Error: Set_Thread_Variables: wta(real) Error Object: ((constant . 1) (profile "" "")) ============================
Old   March 15, 2007, 21:16
Default Re: Fluent New Version 6.3 Problem Help!!!!
suvash
I am also getting the same message. It does not matter. You just open the file in 6.3 version and save there. it will work then with no error...
Regards
Fluent - license problem. Marcin FLUENT 3 April 13, 2018 17:33
problem in defining "libudf" in fluent 6.3 mamun12001 Fluent UDF and Scheme Programming 3 May 16, 2011 04:57
What is the final release version of Fluent 6.3? Paul FLUENT 2 December 8, 2006 09:57
Fluent 6.3 Beta version Aireen FLUENT 2 August 6, 2006 08:02
Rev: Can Fluent 6.0.20 predict this problem right? Yazid Bindar FLUENT 5 March 6, 2003 04:09
