UDF water evaporation
Old   March 12, 2007, 17:34
Default UDF water evaporation
emanuele
hello. In my evaporation model i have written this udf
DEFINE_SOURCE(liq_src, cell, pri_th, dS, eqn)
Thread *mix_th, *sec_th;
real m_dot_l;
mix_th = THREAD_SUPER_THREAD(pri_th);
sec_th = THREAD_SUB_THREAD(mix_th, 1);
if(C_T(cell, mix_th)>=T_SAT){
m_dot_l = -0.1*C_VOF(cell, pri_th)*C_R(cell, pri_th)* fabs(C_T(cell, pri_th) - T_SAT)/T_SAT;
dS[eqn] = -0.1*C_R(cell, pri_th)* fabs(C_T(cell, pri_th) - T_SAT)/T_SAT;
else {
m_dot_l = 0.1*C_VOF(cell, sec_th)*C_R(cell, sec_th)* fabs(T_SAT-C_T(cell,mix_th))/T_SAT;
dS[eqn] = 0.;
return m_dot_l;
The model works but the evaporation is too much fast ( it is completed after only 2 second ) I have tried to use 0,0001 instead 0,1 as relax factor in udf instruction but there aren't many differences in result. What can i change in udf to increase evaporation time?
Thanks a lot
How to simulate the process of water evaporation by UDF? qiyang860908 Fluent UDF and Scheme Programming 10 January 9, 2015 14:59
I need UDF file and tutorial for pool boiling of water omid_h Fluent UDF and Scheme Programming 1 July 24, 2013 10:45
evaporation from open water surfaces nouzha FLUENT 0 December 17, 2009 16:22
Mixture model - water droplet + air - EVAPORATION bohis FLUENT 4 January 25, 2008 12:04
water evaporation Dai FLUENT 3 September 25, 2003 06:02
