domain names - how to specify in Icem Hexa
Old   March 12, 2007, 09:19
Default domain names - how to specify in Icem Hexa
Dr. Flow Squad
I would like to specify my hex mesh with different domain names in order to initialize my 2 phase calculation correct in FLUENT. How do I set up the mesh in ICEM so I in FLUENT will have 2 domains, just lige the tutorial no. 20 in fluent?
Old   March 13, 2007, 02:39
Default Re: domain names - how to specify in Icem Hexa
Charles
You can re-assign the blocks to a new part. By default the blocks belong to the part SOLID, so you can create a new part called SOLID2, for example, and add the blocks to that. Then when you set up the boundary conditions, define the two volume parts as separate fluid or solid domains.
Old   March 15, 2007, 07:34
Dr Flow Squad
Ok Thanks for your help. I'm getting the picture. I have now created what i call LIVE and LIVE2. But how do I actually specify them as two separate fluid domains? Fluent crashes when i read in the mesh.
Old   March 15, 2007, 07:37
Charles
Try saving the two domains as separate unstructured meshes, and reading them separately into Fluent, so that you can see where it crashes.
Old   March 15, 2007, 07:54
Dr Flow Squad
they both crash.... I've attached a plot of the 2D case, maybe that gives a better overview. LIVE2 (purple) should be sand and LIVE (red) air in my fluent multiphase case.
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 23:43
Wind tunnel hexa meshing in ICEM CFD 12.1 matheusguzella ANSYS Meshing & Geometry 1 March 14, 2011 17:14
ICEM hexa mesh built with v10 deformed in v11 (degenerated edges) cfxicem ANSYS Meshing & Geometry 1 October 14, 2009 16:06
ICEM HEXA - Where to start? flattie CFX 3 May 26, 2009 10:12
Import a rectangular domain into CFX 5.7 from ICEM SKLam CFX 9 March 8, 2006 01:47
