Add a layer of cells, dynamic mesh or ...?
Old   March 12, 2007, 00:48
Default Add a layer of cells, dynamic mesh or ...?
Modisa
Hello everyone,
Does anyone know how it would be possible to add a layer of cells to our original geometry during the solving process in fluent. The geometry is simple (2D-strctured mesh). I have a transient problem which needs to add a row of cells to one aspect of original solution during the solving.
Thanks, Modisa
Old   March 12, 2007, 03:01
Default BOUNDRY CONDITION PROBLEM
ammi reddy
hi
i am modeling a pipe flow .helium is flowing through pipe. outside the pipe is water circulate to remove the heat from helium .so heat transer occur from helium to water . i am doing on 2d problem.WALL THICKNESS IS TAKEN AS ZERO . By default it is takes air as outide fluid . how can it be done water is outside the pipe.
[snappyHexMesh] snappyHexMesh not refining surfaces Hydro1004 OpenFOAM Meshing & Mesh Conversion 3 August 29, 2012 12:56
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 13:41
[snappyHexMesh] SnappyHexMeshDict fabrizio OpenFOAM Meshing & Mesh Conversion 25 October 14, 2011 08:00
[snappyHexMesh] Tweaked motorbike tutorial doesn't show my icosphere mfiandor OpenFOAM Meshing & Mesh Conversion 0 October 9, 2011 19:39
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 14:47
