Stream Functions in a 3D problem
Old   March 8, 2007, 12:45
Default Stream Functions in a 3D problem
Shamoon
Hi everybody Dear! I want to see the contours of STREAM FUNCTIONS.
The problem is that my problem is 3D so I donot
get any option for Stream function under Velocity
Cant it happen that I make a plane and observe Stream
Function contours on it? Please help me or if you have any suggestions?
Old   March 9, 2007, 04:10
Default Re: Stream Functions in a 3D problem
Dr. Flow Squad
The Stream Function is not defined in 3D since it is only a 2D flow representation.
Old   March 10, 2007, 10:43
Shamoon
Ok sir, I know that all. and I got your answer but cant I see Stream Functions on a plane. I am still annoyed because I saw a paper in which a 3D problem was done and stream functions were observed! Thanks
Old   March 13, 2007, 16:51
Nak
you can plot the "pathlines" for your 3D case... serves the same purpose for flow visualization.
Old   March 14, 2007, 04:20
Dr Flow Squad
Oil flow on surface maybe?
Old   August 16, 2009, 13:49
Default draw velocity vector, streamline and stream function
Hussam
Hussam is on a distinguished road
Dear Sir
My name is Hussam Ali Khalaf, postgraduate student in Iraq and Am currently working on “A Solution Algorithm for Transient Fluid Flow with Multiple Free Boundaries”
I have results for velocities values (u and v) in directions x and y for undular bore evolution (please, note the file attachment), rectangular uniform mesh (2Dimension, (i,j)=(22,10)) consists of 20 cells in the horizontal direction (length=12 , ∆x=0.6) and 8 cells in the vertical direction (height=1.6, ∆y=0.2).
Am supposed to draw velocity vector, streamline and stream function. I have a program TecPLOT, I have tried several times but I don’t fully understand how TecPLOT reads the results, would you please help me if you have any idea on how to go about it.
Thank in advance
Yours sincerely
Hussam Ali Khalaf
Iraq
Hussam is offline   Reply With Quote
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 05:36
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 06:29
Coordination Frame Problem - strange Luk_Fiz CFX 2 July 30, 2010 09:20
Velocity profiles problem behind the elbow (3D problem) kabat73 FLUENT 8 May 9, 2010 05:26
N-S equations:divergence free functions? D. Puigjaner Main CFD Forum 1 July 27, 2000 13:43
