March 6, 2007, 08:21 |
How to build dynamic mesh?
Hi. Could you tell me the process of building dynamic mesh as well as what I should pay attention to. why does nagative volume exist in mesh motion which I can't understand. Hope u out difficulty.
March 7, 2007, 07:26 |
Re: How to build dynamic mesh? *NM*
March 7, 2007, 09:19 |
Hi. My current undergrad thesis employs dynamic meshing, but I'm afraid my scope of knowledge might be limited because I have no idea what you want to model. Anyway, negative cell volumes arise because your amount of deformation in the dynamic zone is too large compared to the size of the adjacent cells in the adjacent zones. When a node or edge or face deforms extensively it might flatten/quash the cell to the extent where the moving entity passes through one of the cell's faces, when that happens you get negative cell volumes. The mesh update methods of SMOOTHING(spring), DYNAMIC LAYERING(collaspe or split adj layer based on min height) and LOCAL REMESHING is what Fluent has to offer to get around this problem, but there are inherent limitations to all these algorithms FLUENT employs. The best bet is to reduce your timestep size and increase your number of timesteps, essentially this means more and finer instances of mesh updates within the same physical time change. I hope this helps, for further information, you should read the fluent manual on dynamic meshing. Good luck and enjoy!
pls help. mesh collapsed with dynamic mesh. | wlt_1985 | FLUENT | 2 | May 7, 2020 10:42 |
Dynamic mesh is not getting updated. | cardio | FLUENT | 1 | May 20, 2014 08:41 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Some questions about mesh updating in dynamic mesh technique | lzgwhy | Main CFD Forum | 0 | June 14, 2009 08:01 |
