March 5, 2007, 22:06 |
DNS LES validation
Hi. I have got a set of DNS results for a cube with periodic boundaries. I am supposed to assign each value of for example the u,v,w to each corresponding node on a case file in fluent. in other words, im supposed to initialize the solution with values already defined for every node and then run an LES and see how it will perform.
any one knows how to do this? how do u initialize the solution with values already assigned to each node on fluent? assume you have a 100*100*100 cube and a file containing initial values for each node. Cheers |
Mesh size for DNS and LES | Glenn Horrocks | Main CFD Forum | 45 | May 25, 2020 16:43 |
doubt about DNS and LES of combustion | chinthakindi | Main CFD Forum | 5 | August 17, 2013 12:56 |
DNS and LES resolution | Larsen | Main CFD Forum | 0 | November 25, 2010 19:10 |
Need help for DNS and LES methods | Paul | Main CFD Forum | 1 | August 12, 2003 08:22 |
Laminar solver? LES? or DNS? | Ray | Main CFD Forum | 5 | March 19, 2003 11:19 |
