FModellign a Fan Using the Disc Actuator Model
Old   March 3, 2007, 12:42
Default FModellign a Fan Using the Disc Actuator Model
Saif-Deen Akanni
Dear Fluent Users,
I have been dabbling with the disc actuator model in Fluent V6.3.26.
The idea is to try to model the properties of helicopter rotors and ducted fans.
If I only know the thrust that the fan or rotor is producing and the tip velocity, what is the best way to implement the disc actuator model in Fluent?
Regards,
Saif
Old   March 3, 2007, 12:44
Default Modelling a Fan Using the Disc Actuator Model
Saif-Deen Akanni
Dear Fluent Users,
Regards,
Saif
Old   March 12, 2007, 07:25
Default Re: Modelling a Fan Using the Disc Actuator Model
Rahul
Dear Saif, I am dealing with a similar problem to model propeller with an actuator.
Did you find how to go about it. ie what boundary conditions to use ?
- Rahul
Old   March 15, 2007, 04:53
Default Re: FModellign a Fan Using the Disc Actuator Model
hafiz
dear saif, i already install fluent 6.3.21 a few days ago, a prototype downloaded version but i cannot find the actuator disk model. could you tell me how to get it. for your information, i am doing a helicopter simulation both in hovering and forward flight using fluent 6.2, by using both mrf and smm.
i am very interested in actuator disk model because both mrf and smm are near to blade element theory, where the effect of flow as an actuator disk cannot be modeled.
tq.
Old   March 15, 2007, 07:10
hafiz
dear saif,thanks for the reply.
so actuator disc model in fluent is a fan model. i thought it is a new feature in fluent 6.3.
as far as i'm concerned, we must write a udf function to define axial and radial flow through the fan. it is because the induced velocity and wakes generated by main rotor varies with azimuth angle of the helicopter. mrf-moving reference frame model smm-sliding mesh model
tq
Old   November 9, 2011, 22:52
Kwanchai
Kwanchai is on a distinguished road
Dear hafiz, Can you tell me about writing the udf function to define axial and radial flow through the fan??
Now I try to make actuator disk in fluent.
Thank you.
Kwanchai is offline   Reply With Quote
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 09:24
Rotating Disc in a Volume of Air alcesalces OpenFOAM 15 March 18, 2011 09:08
Rotating Disc in a Volume of Air alcesalces FLOW-3D 5 August 28, 2009 18:04
Rotating Disc in a Volume of Air alcesalces Siemens 0 August 24, 2009 14:59
Solver for a Rotatinng Disc in a Volume of Air alcesalces Main CFD Forum 0 August 19, 2009 15:33
