" Divergence detected in AMG solver: temperature" |
March 1, 2007, 17:15 |
I am trying to run a 3D case but each time it diverges. I started with a Laminar - Segregated - Steady case with heat transfer. As that diverged I tried changing Relaxation parameters but that was of no use. I tried unsteady with a 10^-4 timestep. Within 2 time steps it diverged. I even went ahead and saw if it works without without heat transfer, still it diverges. The error message I get is....>> " Divergence detected in AMG solver: temperature" Please Help! Thanks in advance, Suman |
March 2, 2007, 02:36 |
Re: " Divergence detected in AMG solver: temperatu
You must adjust the relaxation factors and numerical method correctly. It depends on specific cases. Please try it again
March 2, 2007, 09:10 |
Thanks Le,
changing the URFs seems to work. Thanks again, Suman |
March 12, 2007, 02:06 |
hi...
this is just my experiance.. try 2 change the temp.. limits in the control panel.. may be high temp.. is there in ur problem..if not try with diff.. discretization methods for temp . just try |
September 11, 2009, 10:31 |
bitak
Rep Power: 17 |
Hi.
I work on project about subsonic ejector like you. My solve is :air - couple - axisymetric - k-e rng - pressure inlet and outlet ideal gas - my presure inlet are 150 ,250 ,350 ,450 Kpa and out let is atmosphere. unfortunately my solve is divergence!!!!!!!!! really I need to your help. I change k-e to k-omega and pressure inlet to mass flow but devegence again.I know i have a shoke and so reverse flow in fluent. |
Error: Divergence detected in AMG solver? | frank | FLUENT | 8 | October 21, 2015 05:38 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 12:34 |
Divergence detected in AMG solver: x-momentum | arashm | FLOW-3D | 2 | August 14, 2010 05:54 |
reverse flow and divergence in AMG solver | MASOUD | FLUENT | 2 | April 2, 2010 09:48 |
Divergence detected in AMG solver | Henriques | FLUENT | 2 | March 1, 2006 23:50 |
