Using define_geom in 3D for a dynamic mesh problem
Old   February 26, 2007, 10:57
Default Using define_geom in 3D for a dynamic mesh problem
John Young
Hi All, I would like to simulate a moving vane close to a fixed body in 3D, using a dynamic mesh UDF and remeshing. I need the surface mesh on the fixed body to 'slide' around the surface as the volume mesh remeshes, without deforming the surface. Define_geom seems the ideal way to do this to specify the surface geometry of the fixed body, but has anyone used this in 3D, to specify a complicated geometry? Any help or suggestions would be greatly appreciated. Cheers, John
Old   September 7, 2010, 13:50
isabel
isabel is on a distinguished road
Try de command DEFINE_GRID_MOTION
isabel is offline   Reply With Quote
Dynamic Mesh problem Paul_321 FLUENT 11 August 11, 2009 12:32
problem on dynamic mesh zone erkan FLUENT 2 January 8, 2009 17:01
CFD-3D flow problem using Dynamic mesh method. Sar_mech FLUENT 1 November 27, 2008 22:17
Dynamic Mesh Problem - please help! Hila FLUENT 0 August 19, 2006 05:19
Dynamic mesh problem Sampath FLUENT 1 October 13, 2004 07:44
