multiphase
Old   February 26, 2007, 06:15
Default multiphase
chak
2d model
outlet 10000000000001 10000000000001 43200000000001 43320000000001----wall(q=0) 12000000000001 10000000000001 10000000000001 10000000000001 10000000000001
i(v_inlet)
hi, iam using above 2d model to study the heat transfer coeffiecient over a 12221 arc that represent the tube and at the inlet 'i' a fluid is passing with upward velociy and the right 1's represents wall and zeros represents where fluid is passing and iam giving constant heat flux at 4411.
iam using multiphase model,mixture, k-e and i got better results(h-heat transfer coefficient) for lower part tube with experimental. But iam not getting for upper part of the tube.
to overcome this I have tried taking the whole model into two halve and using upper half where i am not good result i tried with eulerian model, and passing the values through profile of whole model with previous values of the mixture model at that region.
would u suggest me is it better way of doing it ..or there is any way to do it.
thank you,
please let me know ifany one knows abt it.
Old   February 26, 2007, 06:39
Default Re: multiphase
chak
2d model
----------------------------------------------------------------------------------------------------------------------------- -10000000000001 --------------------------------------------- ---------------------------------------------------------------------------------------------------------------------------------------10000000000001 --------------------------------------------- ---------------------------------------------------------------------------------------------------------------------------------------43200000000001--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------43320000000001----wall(q=0) -----------------------------------------------------------------------------------------------------------------------------------------------------------------------12000000000001---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------10000000000001----------------------------------------------
i(v_inlet)
thank you,
Difference of multicomponent and multiphase homogenous flows Luk_Fiz CFX 11 April 4, 2013 06:29
Use data from multiphase into DO radiation yashmash FLUENT 0 October 7, 2011 04:57
Help: floating pressure, multiphase, closed domain memahfud FLUENT 1 September 24, 2009 04:38
multiphase multicomponent physics ckleanth CFX 3 June 4, 2009 21:15
Multiphase flow modeling Paul CFX 2 August 11, 2003 10:41
