turublence parameters.
Old   February 26, 2007, 06:05
Default turublence parameters.
chandra Mohan
hi,
i am simulating turbulent flow over a ellipse and rectangle. i want to know how to calculate the Turbulence Intensiyt(I) and what length scale to adapt. i am using fluent 6.2 software. also how to compute and meshing strategy for the wall Y+
Old   February 28, 2007, 10:34
Default Re: turublence parameters.
Pratik Mehta
turbulent intensity is given by standard deviation/mean velocity,
where do u have to specify this number , i think it will either at the entrance or and exit ,depending on your domain , keep the value low at the exit to prevent the back flow , generally turbulent intensity is given very small, but yes this quite depending the case u r solving
can u tell me whats your geometry ?
Geting y+ is purely a trail n error method or a smart guess that comes from experience , or if u get a very simple geometry probably u must be in a position to get the estimation fo y+,
Let me know have i answered u properly or not
Old   March 1, 2007, 00:16
chandra Mohan
thnq for ur reply,
my geometry is 2D, ellipse with max .length of 26m height of 11m.
i want to specify the turbulence parameter at inlet velocity,
also for y+ should be within 30.
i am using fluent software to simulate external flow over an ellipse of major dia 2m and minor dia 1m. to calculate the drag and lift coefficient.
Old   March 1, 2007, 06:45
Pratik Mehta
is the flow over the the major axis or minor axis, i mean the placement of the geometry with respect to the flow
Old   March 1, 2007, 06:53
Pratik Mehta
knowledge of turbulence parameters at the entrance will come from the wind tunnel experiments , generally it is this way, but as far my experience is concerned , keepin the intensity about 0.001 should be ok , n for the outward it should be less 0.01% or something , or less enough to aviod the back flow at the pressure outlet
i hope this helps u ,,
other people reading this suggestion could u please put in suggestions over my comments
Old   March 1, 2007, 09:35
chandra Mohan
major axis
Old   March 2, 2007, 03:57
Ness
I've read the thread and I always put a turbulence int. of 1 for external flows at the inlet, and the same for the pressure outlet (in fact, this data are provided in the case of backflow, so the backflow is previous to the using of this data at the outlet).
I recommend, in any case, to take some well-known cases and try to get the same results ( I mean, simple geomteries whose drag and lift are tabled)
regards
Old   March 2, 2007, 07:24
chandra Mohan
ok, thankyou,
i will try that.
twoPhaseEulerFoam - parameters grjmell OpenFOAM 1 June 16, 2011 09:13
units of geometrical parameters lost SoobY ANSYS Meshing & Geometry 2 January 10, 2011 04:58
Coal Particle Tracking Parameters Michael FLUENT 1 December 1, 2007 15:51
New to CFX-need explanations about mesh parameters Cyril CFX 3 November 24, 2006 07:33
expert parameters of SST model? David CFX 1 December 2, 2005 07:36
