Need help in postprocessing a combustion
Old   February 23, 2007, 03:08
Default Need help in postprocessing a combustion
HSeldon
Hi, Iīm dealing with an IC engine and basically I need to know if all the mixture is burnt or how is the percentage of burnt mixture. When I see the Fluentīs documentation (chapter 16, section 2.1) I can see a variable "c", the progress variable. 0 means unburnt and 1 means totally burnt. Where can I found that value for postprocessing? I hope I was clear! Thank you in advance.
Old   February 23, 2007, 03:25
Default ALSO!
HSeldon
If you canīt access that value from the Fluentīs GUI, do you know the name of the variable in order to access it from an UDF?
Thank you!
Modelling Combustion in Porous Zone tanjinjack FLUENT 2 September 26, 2016 05:10
hydrocarbon gases + Boron particle combustion nileshjrane OpenFOAM 1 December 13, 2010 07:20
Hydrogen Air combustion in a combustion chamber popi CFX 7 July 11, 2007 19:40
A role of combustion modeling in flow solver? Yoon Main CFD Forum 0 November 26, 2006 13:00
Need Similar Combustion Tutorial as my model Arnab Siemens 0 May 24, 2005 19:23
