February 21, 2007, 18:59 |
Convergence issues
When running a turbulent case in Fluent, I am getting a message stating that the turbulent viscosity ratio limited to 1.0e+5. Does anyone know how to fix this?
February 23, 2007, 01:55 |
Re: Convergence issues
Are you usung standard-k-e? Try realizable k-e. Perhaps it gets better.
February 23, 2007, 05:16 |
be patient ... it needs some time to converge ... some more iterations ... try to adjust under-relaxation parameters
wabik |
February 23, 2007, 14:07 |
What do you want to fix? Make the message go away - then change the tolerance in the set-up. If the value is unrealistically high, then you would take a different approach.
Convergence | Centurion2011 | FLUENT | 48 | June 15, 2022 00:29 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 23:03 |
convergence issues on steady state solver | icemaniac178 | CFX | 1 | March 30, 2011 20:11 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 02:17 |
Grid size, convergence issues | franzdrs | Main CFD Forum | 3 | June 18, 2009 08:57 |
