added mass
Old   February 20, 2007, 17:11
Default added mass
Kuba Broniszewski
Hi! Has anybody been concerned by the problem of added mass in the presence of free surface? We are starting to investigate this phenomenon on the models in the laboratory and we want to compare our results with CFD calculations. What kind of UDF sholud be written?
Regards
Kuba Broniszewski
Old   February 23, 2007, 09:52
Default Re: added mass
Bak_Flow
Dear Kuba,
can you explain the physics of the problem better.
Are you refering to "virtual mass" which is a term that shows up when one looks at the force on a submerged body moving through a fluid?
regards,
Bak_Flow
Old   February 23, 2007, 10:39
kp
Bak yes it is indeed the same. Virtual mass is important in two instnaces 1. While trying to dampen the instantaneos fluctaution in turbulence..Tchens theory, 2. In bubbly flows. Fluent cannot handle VM properly in momentum eqautions. Leads to divergence for gas liquid flows. but I have made it possible to work wiht it. Is tricky. If yo encounter difficualites mail me at kp@dal.ca
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Abt: Added mass effect in compressible flow. jinwon park Main CFD Forum 0 August 2, 2007 15:43
Calculation of added mass in viscous flow kharati Main CFD Forum 2 February 1, 2006 01:28
Added Mass in a 2-D Cylinder Rahul Bharadwaj Main CFD Forum 0 March 2, 2005 14:11
