udf:surface reaction:volumetric reaction: compile
Old   February 16, 2007, 16:46
Default udf:surface reaction:volumetric reaction: compile
Ali
hello all
I have some problem using a udf to define both surface and volumetric reaction in one udf file. it compiles the file but when I put a message in the surface reaction connamnd, DEFINE_SR_RATE( .......), it does not show any message on the screen.
Please help me
Thanks
Old   February 16, 2007, 23:48
Default Re: udf:surface reaction:volumetric reaction: comp
Rizwan
Can u please be a bit more eloborate?
Old   February 18, 2007, 04:20
Ali
I compile my udf file successfully. I hook the name of the function in the hook panel. but it seems that when I star iterations fluent does not go to udf file at all. I put a command line to get it show me if it enters the udf file or not. but it does not show me any message on the screen. I use "Message("%s \n", r->name)" to see which reaction is adjusted. but it prints nothing.
Thanks for your consideration
Segmentation fault in running alternateSteadyReactingFoam,why? NewKid OpenFOAM 18 January 20, 2011 17:55
reaction in UDF(DEFINE_VR_RATE) louiza FLUENT 3 October 14, 2010 00:59
CFX5.7 - chemical reaction problem... H.L. CFX 4 March 25, 2009 11:33
Can someone PLEASE document the development version installation bernd OpenFOAM Installation 76 November 14, 2008 22:51
chemical reaction - decompostition La S. Hyuck CFX 1 May 23, 2001 01:07
