species mass source in porous media ?
Old   February 16, 2007, 12:12
Default species mass source in porous media ?
PK
Hi ,
I have 2D case : cylinder (porous media) which is in a much bigger Control volume(non porous) (flow is from inlet to outlet,...). This cylinder is acting like a sink of species.
When I am running a simulation WITHOUT removing specie in this 2D cylinder NON POROUS media and another as a POROUS media : In both cases I have the same species mass fraction,VOLUME Integrale,Vol Avg, Mass Int and Mass Avg in this 2D cylinder zones (porous or Non porous).
To remove a certain amount of specie (in the cylinder) ,I use a UDF(DEFINE_SOURCE) with Si = Mass of specie in cell(i)/ SUM(vol cell(i)).
A)If the cylinder is NonPorous : Non prob.
B)If the cylinder is Porous : There is a Prob : Even though , species have same mass fractions(Porous /non porous) , there is less Species avalaible (less flow rate ) in the cylinder(in the non porous case) : and so there is the not the same amount left in both Cases (less in the porous case).
Q: How this Si (source term) is linked to the local mass flow rate in a cell i ? ; How to solve this problem then ?.
Thanks for any help
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 17:02
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
Add source term in species equation zhou1 FLUENT 1 October 21, 2003 07:28
mass transfer in porous media?? yee wan FLUENT 0 December 23, 2002 21:39
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 04:43
