February 14, 2007, 05:30 |
What is mixture fraction variance?
Hello Users,
In the non-premixed combustion model, what is mixture fraction variance, and more importantly how should it be specified at the the fuel inlet? Thanks, Hugo. |
February 14, 2007, 10:23 |
Re: What is mixture fraction variance?
f=prom(f)+f'
i think f'=0 at le inlet, in fact i've done |
April 20, 2015, 15:57 |
sanjeet Limbu
Rep Power: 11 |
Hi I am trying to ignite the mixture(N2/Ar/O2/nc7h16): 58/30/10.307/0.562 by mole fraction I made the species PDF using the chemkin file . The mixture is as fluid for the mesh body which will be compressed by piston. So I put mixture fraction and mixture variance as zero- in initilaisation . Is this correct for a compression stroke in the 2D asymmetric plane
If the Initial temperature need to be 298K ... I am not getting that as initial temperature I am getting 336K... |
April 20, 2015, 22:24 |
sanjeet Limbu
Rep Power: 11 |
Dear frd
I am not getting pressure due to insufficient mixture quantity in my closed system... how to initialize the mass or quantity... As there is no inlet boundary.. but it will be closed vessel compressed case... |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
CFX Solver Memory Error | mike | CFX | 1 | March 19, 2008 08:22 |
Mixture fraction for combustion problem | Jonathan Lemay | CFX | 3 | November 5, 2007 15:57 |
mixture fraction | Sheng Chen | Main CFD Forum | 0 | October 6, 2004 02:33 |
