How can I simulate a wheel inside a brick?
Old   February 10, 2007, 08:44
Default How can I simulate a wheel inside a brick?
Jordi Niubo
How can I simulate a wheel revolving at an specific speed inside a brick with a velocity inlet with a different speed? I tried with a multiple reference frame but it doesn't account for fluid dynamic interaction between stationary and rotating components. I can't ignore the relative motions of the two zones with respect to each other...
Thank you!
Jordi
Old   February 12, 2007, 10:34
Default Re: How can I simulate a wheel inside a brick?
Jason
MRF should account for interaction between the components but only at that instantaneous orientation you've modeled. If you need to see the changes as the geometry moves you need to model using the Sliding mesh technique and run an unsteady calculation. The Fluent Users Manual says that the MRF solution can be a good starting point for your unsteady sliding mesh calculation.
Hope this helps, and good luck, Jason
How to simulate a simple fan inside a room ? rafiktharwat CFX 10 September 23, 2014 03:51
Simulate a fan inside a larger domain gregoire FLUENT 8 June 21, 2013 13:04
Modeling Rotating wheels inside a wheel fairing. robinfisichella STAR-CCM+ 0 May 1, 2010 09:19
Creating a grid for a channel inside a brick sanin FLUENT 0 November 6, 2008 09:03
meshing F1 front wing Steve FLUENT 0 April 17, 2003 13:37
