subroutines in UDF
Old   February 7, 2007, 15:10
Default subroutines in UDF
kk
Can any one tell me is it OK to include other subroutines (Calculate some values and return the values into the UDF main) in the UDF? I tried once, but it seems it couldn't be complied. BTW, I am using the EXPRESS VC++ .
Old   February 8, 2007, 02:36
Default Re: subroutines in UDF
Bogdan
yes is ok, I have a main file a header file and a functions file and it works fine.
Old   February 8, 2007, 15:20
kk
what does this message mean?: "udf limitation: Intensity: prototypes must appear outside the function body."
'Intensity' is a subrountin in my UDF.
Old   February 9, 2007, 02:38
Bogdan
in your header file you should declare the prototype of your function (what parameters take, if return a value), or if you don't have a header file after the #include statements put your function prototype.
Dynamic Mesh UDF Qureshi FLUENT 7 March 23, 2017 08:37
UDF parallel error: chip-exec: function not found????? shankara.2 Fluent UDF and Scheme Programming 1 January 16, 2012 23:14
How to add a UDF to a compiled UDF library kim FLUENT 3 October 26, 2011 22:38
UDF...UDF...UDF...UDF Luc SEMINEL FLUENT 0 November 25, 2002 05:03
UDF, UDF, UDF, UDF Luc SEMINEL Main CFD Forum 0 November 25, 2002 05:01
