Laminar flow
Old   January 31, 2007, 21:41
Default Laminar flow
mech
Dear all
Have you had any problems with laminar flow?
My numerical modeling deal with lamiar flow. I just though that numerical modeling for laminar flow would be simple.
But, numerical data does not match with experimental data. I do not say the data value.
The trend is different.
For example, imagine that temperature of number 1 sample is higer than number 2 sample. But, numerical results are opposite
I have tried to match numerical data with experimental data. ( increase mesh number, change mesh , 3d dp, SIMPLE/SIMPLEC/PISO, second order momentum/pressure/energy, etc )
I couldn't.
Actually, for laminiar flow, there are very few setting to change comparing to turbulent flow.
Do you have any ideas?
Thanks
Old   February 1, 2007, 04:10
Default Re: Laminar flow
wabik
I have a similar problem with laminar flow. In my case oscilations of temperature are much higher then experimantal data and similar to your case there is not much to change in the model
Brgds, wabik
Old   February 1, 2007, 13:45
kk
I think near wall treatment is the critical part in laminar flow modeling. I am going to do the experiment and the laminar flow too. Hope my intensive grid near the walls can help. Crossing fingers.
Old   February 1, 2007, 15:10
mech
Hi. Wabik
I have also a same problem.( oscilations of temperature )
In my case, as I increase mesh number, I check the temperature. When I used small number of mesh, there was no oscilations of temperature. But, at the large number of mesh, there was oscilations of temperature.
I think that oscilations of temperature maybe depends on mesh number or mesh quality.( Of cousre, not always )
To match numerical data and experimental data, I try to change discretization scheme. As you can see, there are very few things to change for laminar flow.
Do you have any experience to change discretization scheme as you are doing a numerical modeling?
Old   February 1, 2007, 15:18
mech
Hi. kk
I hope your research go well.
In my case, I also increased mesh numbers near wall. But, there was not a significant difference. I checked up to 2,600,000 mesh.. -_-
So, I try to change discretization scheme so that I match numerical data with experimental data, . As you can see, there are very few things to change for laminar flow.
Good luck!!
Boundary Layer of Laminar Flow over a Flat Plate Blasius_Pohlhausen_Crocco Main CFD Forum 12 September 30, 2013 18:35
Can I use turbulent model to solve a laminar flow? nikhil FLUENT 5 February 1, 2011 11:42
How to enforce laminar flow while using k-e Grzegorz Kondora FLUENT 0 January 28, 2009 11:35
grid for laminar flow kim FLUENT 2 April 4, 2002 03:44
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
