UDF for trap of dpm
Old   January 31, 2007, 15:44
Default UDF for trap of dpm
HK
Hello, I wanted to trap particles as soon as certain condition is fullfilled (not on wall). For example, trapping particles on dis=2e-3 m where dis= distance from the wall and particle centre.
regards, HK
Old   February 1, 2007, 15:24
Default Re: UDF for trap of dpm
Allan Walsh
You should be able to use the variable P_POS(p)[i] which is the position of the particle, p. The variable, i is the direction, x=0, y=1, z=2. (This is for Fluent 6.2, it was different in v6.1).
If particle position > dis then return PATH_END.
You can even increment the variable for the number of particles trapped, gvr_trapped?. Look for it in the dpm.h header file, if it is of interest. Good luck.
Old   November 8, 2016, 10:43
raa
rdfing is on a distinguished road
Originally Posted by Allan Walsh
;138801
Isn't DPM boundary Macro only detect and point to those particle that touch the wall?
rdfing is offline   Reply With Quote
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT subhankar_bhandari Fluent UDF and Scheme Programming 0 August 19, 2010 04:09
Hooking a DPM Particle Heat and Mass Transfer UDF to FLUENT subhankar_bhandari FLUENT 0 August 19, 2010 04:01
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
DPM with UDF - Step-by-Step Procedure???? Prashanth FLUENT 3 April 3, 2009 18:45
DPM - UDF for fluctuating bubble size Jaroslav Kotara FLUENT 1 April 19, 2006 10:02
