Porous Cylinder in a flow
Old   January 31, 2007, 05:25
Default Porous Cylinder in a flow
PK
I would like to know if it is possible to simulate this problem of a porous cylinder in a flow. It is 2D case ; Basically these porous cylinder are used to filter the flow (which containst different species). The problem is that I don't have any experimental data and we just assume that porosity of the cylinder is 5%. How to use the porous media feature in FLUENT to simulate this prob. Due to the lack of info I can't use exactly the model available : viscous and inertial coefficiants ,... ; I have only the "fluid porosity".
Thanks for any kind of help
Old   January 31, 2007, 09:51
Default Re: Porous Cylinder in a flow
Pablo
you have to get from somewhere a "Pressure loss .vs velocity" law, try here, WWW.GOOGLE.COM,
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 11:05
Flow past 2 smooth circular cylinder slip FLUENT 0 July 8, 2010 19:45
species mass source in porous media ? PK FLUENT 0 February 16, 2007 12:12
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 15:32
