How to monitor variable evolution on centerline?
Old   January 30, 2007, 16:49
Default How to monitor variable evolution on centerline?
Konring
I am very interested in monitoring a variable on a line ( for example, a varible on the axial centerline in X-Y plot). In doing so, I could know what is the each-time-step change of a key variable during the unsteady state simulation.
How to realize it in Fluent? Could you giveme some suggestion.
Old   January 31, 2007, 00:27
Default Re: How to monitor variable evolution on centerlin
Ragh
Go to Solve-->monitor--->surface surface monitors increase it to 1 you can switch on Plot, print and write according to your needs. U can select Time step in when drop down list and from define you will reach to a window where you can define the variable and surface. Cheers
Old   January 31, 2007, 13:06
Konring
Hi, Ragh, Thanks.
I still do not understand clearly. I want to plot for axample "gas axial velocity vs. radial coodinate". Then monitor the evolution of this curve with time.
So, the specific questions:
(1) How to set REPORT TYPE (Integral,area-weighted average, flowrate..) ?
(2) How to set the radial coordinate as I expect?
Hope to get your further help for this.
Old   January 31, 2007, 16:51
Ragh
Report type you can set when a window pop up when u say define. But I think that u cant monitor the variable on everywhere on a local co-ordinate, u can only monitor its avg value or value at a point. If you want to monitor it on radial co-ordinate, u need 3 axes for that...I dont know if Fluent can give u so much results and also It will eat lot of memory. Alternatively what you can do is that U can have max allowed monitors (3 or 4)in Fluent on diff radial co-ordinates(start, 0.25r,0.5r,0.75r and r) and afterwards postprocess them as u wish. Hope this does help Cheers
Old   January 31, 2007, 17:24
Konring
Ragh,
It is a good idea to use the max. monitor number (<=4)to realize my aim alternatively. Thanks a lot for your suggestion.
Time Evolution of TKE (LES) MaryBau OpenFOAM 1 March 22, 2011 08:40
Interfoam (OF 1.7) : pressure evolution, impact, 2D computation kassiotis OpenFOAM 2 December 21, 2010 16:09
evolution of the size of air conditioner ztdep Main CFD Forum 0 July 1, 2010 01:37
gradient(gamma) at centerline? dany OpenFOAM Running, Solving & CFD 0 August 3, 2009 04:10
centerline in cyl. coord. Daniel Main CFD Forum 2 December 30, 2004 01:10
