Questions about gas-solid fluidized bed simulation
Old   January 30, 2007, 16:01
Default Questions about gas-solid fluidized bed simulation
Sinferm
There is a paper having the following description for setting the intial and boudary condition for the simulation of gas-solid fluidized bed. (see below for details).
Now, my questions are that:
(1)In Fluent, how to set "Initially the riser column was empty"? When I set the solid fraction to be zero in Fluent Intilization section, I found the gas fraction equals unit. It seems not to correspond to the "empty".
(2)For gas-solid system, the solid-wall interaction should be considered. As noted in that paper, the classical "Johnson and Jackson (1987) boundary condition was used". Now, my question is: How to set the Jackson condition in Fluent? Especially for the proper choice of restitution coefficents concerned.
Really hope to get the help and ideas from those who have specific experiences in treating the gas-solid fluidized bed simulation. Thnaks in advance.
************************************************** ********* "...The definition of appropriate initial and boundary conditions is critical for carrying out of a realistic simulation. Initially the riser column was empty and the velocities of both phases were assumed to be zero. At the outlet, atmospheric pressure was prescribed. Particularly important is also the specification of appropriate boundary conditions at the wall. For the gas a no-slip boundary condition was used. For the granular temperature wall boundary condition the Johnson and Jackson (1987) boundary condition was used. It was obtained by equating the granular flux to collisional dissipation with a correction for slip, as shown in Table 1...."
Old   January 31, 2007, 15:54
Default Re: Questions about gas-solid fluidized bed simula
Ganna
Hi, Sinferm,
I met the same problem. In my simulation, the Euler-Euler approach is used to simulate the gas-sloid riser. Johnson and Jackson condition is used as solid-wall boundary condition. But I always find that the axial solid velocity at the wall boundary is zero, albeit I do not use the no-slip condition. I guess I do not manage the boudary setting,too.
I want to know why? and how to avoid it?
expansion of bed in fluidized bed achy7pch FLUENT 7 August 10, 2024 04:33
Simulation of Gas & Solid Phase Reaction in FLUENT zdz198728 FLUENT 1 March 14, 2011 05:55
Simulation time for unsteady gas solid flow pandaba FLUENT 1 October 14, 2010 01:04
Problem with fluidized bed simulation using TwoPhaseEulerFoam matthias_schreiber OpenFOAM Running, Solving & CFD 5 June 12, 2008 07:49
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
