Neighbouring Cells
Old   January 29, 2007, 16:01
Default Neighbouring Cells
Carlos V.
Hi everybody:
I'm simulating a reforming system. I need to access some variables (like a User - Defined Scalar quantity) in the neighbouring cells of each cell of my domain. Can anyone help me on this?
Thanks! Carlos V.
Old   January 30, 2007, 02:59
Default Re: Neighbouring Cells
Bogdan
See the answer http://www.cfd-online.com/Forum/fluent.cgi?read=45754
Old   January 30, 2007, 11:26
Carlos V.
Thank you very much Bogdan.Can you give an example of a code that uses that implementation to access a variable in a DEFINE_ADJUST macro? I've already tried to implement that in a original code, but had no success! Really need help on this. Thank you once again!
Carlos
Old   January 31, 2007, 12:05
Bogdan
void neighboringCells(cell_t* n_cell,Thread* n_thread[],cell_t cell,Thread* cell_thread){
**This function gets the neighboring cells and threads (if exists) for a given cell
**and thread. The order is left x, right x, back y, front y, bottom x, top z.
**Bogdan Nichita nov.2006****************************************** ****************
face_t face;
Thread *face_thread;
int n;
real xc[ND_ND],xf[ND_ND];
real min_xf,max_xf,min_yf,max_yf,min_zf,max_zf;
C_CENTROID(xc,cell,cell_thread);
min_xf=max_xf=xc[0];
min_yf=max_yf=xc[1];
min_zf=max_zf=xc[2];
c_face_loop(cell,cell_thread,n)
face=C_FACE(cell,cell_thread,n);
face_thread=C_FACE_THREAD(cell,cell_thread,n);
F_CENTROID(xf,face,face_thread);
if (xf[0]>max_xf){
max_xf=xf[0];
if (BOUNDARY_FACE_THREAD_P(face_thread))
n_cell[1]=-1;
n_thread[1]=NULL;
}else{
n_cell[1]=F_C1(face,face_thread);
n_thread[1]=THREAD_T1(face_thread);
if (n_cell[1]==cell && n_thread[1]==cell_thread){
n_cell[1]=F_C0(face,face_thread);
n_thread[1]=THREAD_T0(face_thread);
if (xf[0]<min_xf){
min_xf=xf[0];
n_cell[0]=-1;
n_thread[0]=NULL;
}else{
n_cell[0]=F_C1(face,face_thread);
n_thread[0]=THREAD_T1(face_thread);
if (n_cell[0]==cell && n_thread[0]==cell_thread){
n_cell[0]=F_C0(face,face_thread);
n_thread[0]=THREAD_T0(face_thread);
if (xf[1]>max_yf){
max_yf=xf[1];
n_cell[3]=-1;
n_thread[3]=NULL;
}else{
n_cell[3]=F_C1(face,face_thread);
n_thread[3]=THREAD_T1(face_thread);
if (n_cell[3]==cell && n_thread[3]==cell_thread){
n_cell[3]=F_C0(face,face_thread);
n_thread[3]=THREAD_T0(face_thread);
if (xf[1]<min_yf){
min_yf=xf[1];
n_cell[2]=-1;
n_thread[2]=NULL;
}else{
n_cell[2]=F_C1(face,face_thread);
n_thread[2]=THREAD_T1(face_thread);
if (n_cell[2]==cell && n_thread[2]==cell_thread){
n_cell[2]=F_C0(face,face_thread);
n_thread[2]=THREAD_T0(face_thread);
if (xf[2]>max_zf){
max_zf=xf[2];
n_cell[5]=-1;
n_thread[5]=NULL;
}else{
n_cell[5]=F_C1(face,face_thread);
n_thread[5]=THREAD_T1(face_thread);
if (n_cell[5]==cell && n_thread[5]==cell_thread){
n_cell[5]=F_C0(face,face_thread);
n_thread[5]=THREAD_T0(face_thread);
if (xf[2]<min_zf){
min_zf=xf[2];
n_cell[4]=-1;
n_thread[4]=NULL;
}else{
n_cell[4]=F_C1(face,face_thread);
n_thread[4]=THREAD_T1(face_thread);
if (n_cell[4]==cell && n_thread[4]==cell_thread){
n_cell[4]=F_C0(face,face_thread);
n_thread[4]=THREAD_T0(face_thread);
Old   February 1, 2007, 09:45
Carlos V.
Thank you very much Bogdan!
I'll see if I can get this to work! Thank you once again.
Carlos Ventura
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
physical boundary error!! kris Siemens 2 August 3, 2005 01:32
