UDF help (about temp gradient)
Old   January 29, 2007, 10:08
Default UDF help (about temp gradient)
Jihwan
Hi
I have a problem accessing the temperature gradient in a UDF.
I want to give temperature gradient on the 2-D wall.
(Methematical fucntion is T(x)= 30 + ( 1.5 * lxl )
I spent a lot of time with manual. But I failed.
I need your help.
Old   January 29, 2007, 10:59
Default Re: UDF help (about temp gradient)
pinks
Use DEFINE_profile macro, F_T and F_centroid. read centroid of the cell, assingn x(0) to a variable, and define the function on each face as F_T(f,t)= 30 + (1.5 * fabs(a)).where a=x(0). I hope this should work. All the best.
Old   January 29, 2007, 11:12
Jihwan
thanks for your advice.
I tried..
But that couldn't interpreted..
and I don't know what is problem..
when I tried interpreted, than message came out -line 13: a: undeclared variable
can you help me?
my ccp file is
************************************************** * #include <udf.h>
DEFINE_PROFILE(temp_wall,thread,position) {
real x [ND_ND];
real r,y;
face_t f;
begin_f_loop(f,thread)
F_CENTROID(x,f,thread);
a=x[1];
F_T(f,thread)=30.+(1.5*fabs(a));
end_f_loop(f,thread) }
Old   January 29, 2007, 11:29
pinks
you have not defined variable a, use r instead or define real a instead of real r,y; ur udf. u r using x[1], i hope ur wall is in y direction.
Old   January 29, 2007, 11:45
Jihwan
thanks a lot. I succeed interpreted. but I failed compiling..
massage aappear
"pening library "Temp_wall"...
Error: open_udf_library: μ§€μ •λœ νŒŒμΌμ„ 찾을 수 μ-†μŠ΅λ‹ˆλ‹€.(<--KOREAN)
Error Object: ()"
what's prlblem?
Old   January 29, 2007, 11:49
Jihwan
And my wall is in X direction
--------------------------->(wall-direction)
and My changed cpp file is
#include <udf.h>
real x [ND_ND];
real a,y;
face_t f;
a=x[1];
Old   January 30, 2007, 00:40
pinks
Hi, I am able to compile as well as load. try the following udf. Keep the [filename].c file in your working directory.. and confirm that you have a c compiler.
#include "udf.h"
real x [ND_ND];
real a,y;
face_t f;
a=x[0];
Old   January 30, 2007, 00:41
pinks
x[0], x[1], x[2] stands for x,y and z dirctn respetively. If you ahve your wall in x direction use x[0]
Old   January 30, 2007, 01:04
Jihwan
Thanks a lot Pinks.
I use visual C++.
But I don't know why didn't compiling.
I'll try again. (I got it about problem. udf coding is work, and compiler has a problem. is correct?)
And can I ask again if I continually failed ?
Have a nice day.. see ya
Old   January 30, 2007, 02:10
Jihwan
Finally, I found problem.
my c compiler has not udf.h file.
bottom is message when try compiling to use C++
--------------------Configuration: temp_wall - Win32 Debug-------------------- Compiling... temp_wall.cpp d:\fluenty\c++\temp_wall.cpp(1) : fatal error C1083: Cannot open include file: 'udf.h': No such file or directory Error executing cl.exe.
temp_wall.exe - 1 error(s), 0 warning(s)
how can I do it ?
Old   January 31, 2007, 01:02
  #11
pinks
Fluent provides free compiler visual studio.NET at the following link http://www.fluentusers.com/support/i...udf_serial.htm. If you are licensed user you can download. You just need to launch Fluent the .net command prompt.
UDF to Access Wall Normal Concentration Gradient Daniel Tanner Fluent UDF and Scheme Programming 4 February 18, 2015 15:35
specified shear at wall - temperature gradient - UDF - access violation error senD Fluent UDF and Scheme Programming 9 September 18, 2014 08:29
UDF temp gradient tutotial tejasvikrishna FLUENT 0 April 4, 2011 12:10
UDF for Species Mass Fraction Gradient *IN SPECIFIC ZONE * -- e.g. along axis of sym. ksiegs2 Fluent UDF and Scheme Programming 0 February 27, 2011 13:55
UDF for species-mass-fraction gradient at outlet sisir FLUENT 0 June 9, 2007 03:40
