Possible to fuse two different Gambit geometries? |
January 26, 2007, 11:31 |
Hi all,
I created a geometry with Gambit and would like to fuse it with a geometry created by my coworker (also in Gambit). In essence, my file constitutes the top half of our model, and the other file is the bottom half. Both files are currently saved as *.dbs. I need to know how to manipulate both files into the same workspace. After that, I understand how to realign, translate, scale, and unite volumes. So, how can I take two different *.dbs files and open them in the same workspace? Thanks in advance, Amit |
January 26, 2007, 18:43 |
Re: Possible to fuse two different Gambit geometri
Look into the fluent tutorial with grid interfaces. It is very well explained there.
January 26, 2007, 19:22 |
i think you can export one of the geo as gambit neu file and import again with another , it should work.
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 13:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 09:33 |
How to fuse two differents geometries with Gambit? | RĂ©mi CASSAR | FLUENT | 2 | July 12, 2007 05:08 |
GAMBIT Problem ,,,very thin geometries | Meenu | FLUENT | 3 | March 24, 2006 10:42 |
Gambit - Virtual Geometries (Pro's & Con's) | James Date | FLUENT | 3 | August 11, 2003 16:46 |
