How to activate just one phase turbulence model? |
For modeling two-fluid gas-solid system with considering turbulence effect, the Eulerian-Eulerian approach is to be applied. The gas phase is defined as continuous phase and the solid phase as dispersed phase. As we know,there are three options for K-E equation multiphase model(Fluent 6.2.16): (1) mixture; (2)dispersed; (3)per phase.
The question is: If I just want to activate or consider the turbulence model for one of the two fluid phases (for example the gas phase), what should I do? In other words, how to set the option for that purpose? Thanks in advance for your idea? |
if u choose dispersed, u will consider only the gas turbulence if u need to turn on the 2nd phase turbulence equation, u have to choose "per phase"
I didn't use the "mixture" option and i don't know which equations will be used or neglected Yasser |
Modified k-e turbulence model UDF | Travis | Fluent UDF and Scheme Programming | 7 | November 11, 2018 20:21 |
Turbulence postprocessing | Mohsin | FLUENT | 2 | October 3, 2016 14:18 |
build your own turbulence model with buoyancy | Thomas Baumann | OpenFOAM | 11 | November 23, 2009 08:53 |
v2-f turbulence model in CFX? | flga | CFX | 14 | November 23, 2006 06:12 |
Turbulence model | Herry | Phoenics | 1 | May 29, 2003 13:19 |
