Discreate Particle Method: Introducing solids
Old   January 25, 2007, 02:37
Default Discreate Particle Method: Introducing solids
kris
Hi all, I need to introduce solid particles, which freely suspend in air. Can I use DPM? If so, then how to introduce particles using DPM?
Thankyou, -kris
Old   January 25, 2007, 03:48
Default Re: Discreate Particle Method: Introducing solids
rams
do u want to inject particles, so that they mix with contiuous phase and move on? If so then u can use DPM model, there are many injection types available in fluent, go through the fluent user guide to know how to that.
or
do u want to suspend particles at some location in the domain?
If so the use multiphase model & add a patch in the domain with the particle (material) u want. go through the user guide to know & use those options
Old   January 25, 2007, 07:03
kris
Thankyou, I'll go thru user guide regarding DPM.
Old   August 18, 2010, 03:39
rj
robjac is on a distinguished road
Hi ,
I am facing problem in Discrete phase modelling with suspended particles in a closed vessel of fluid.The suspended particles in the fluid is to be heated in a closed vessel at a fixed volume concentration.But how to make the particle suspended before the heating is done at a fixed concentration, without any inlet and outlet flow?
Suggestion from ur side would be of great help..
Regards,
Rob
robjac is offline   Reply With Quote
Particle tracking Method?? hado STAR-CCM+ 3 December 30, 2014 17:49
Is Particle Finite Element Method applied in CFX? WenZyn Lim CFX 0 April 6, 2011 12:47
Discrete Particle method Query Mohsin FLUENT 0 March 2, 2010 23:20
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 02:29
Vortex Particle Method Gerrit Main CFD Forum 3 June 27, 2006 05:22
