cross section visualization
Old   January 24, 2007, 02:18
Default cross section visualization
Nelly
Hi, Does anyone know how to view the velocity contour of the cross section of a model? Thanks in advance!
Old   January 24, 2007, 02:41
Default Re: cross section visualization
sachin
Hi Create a surface wherever you require by Plane Surface in Surface menubar.Then plot velocity contours for that perticular section.
regards Sachin
Old   January 24, 2007, 07:35
Nelly
I heard from my prof tt there's a slicer kind of thing tt can just slice the cross section. Do you know about it?
Old   January 24, 2007, 08:51
Jason
You can used Display->Sweep surface, but I'd recommend creating fixed faces unless you plan on creating animations based on sweeping the surface. Moving the face is essentially creating a new interpolation plane and destroying the last. If you have to make multiple plots on the same surface, then you end up wasting a lot of time and computing power using the sweep surface. But if your goal is to make an animation, or if you're using it to scan back and forth across a feature, then a Sweep surface will work pretty well.
Good luck, Jason
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 17:14
how to assign cross section to line body? fizie ANSYS 0 March 17, 2011 10:41
Straight fin of unform cross section Agovale46 FLUENT 0 September 30, 2009 09:52
cross section average Paul FLUENT 0 April 12, 2006 12:30
Cross section and surface area factor Fabiana CFX 0 January 10, 2006 00:51
