combining structured and unstructured grids
Old   January 23, 2007, 10:37
Default combining structured and unstructured grids
Shane
I am attempting to create a mesh for an entire aircraft and am looking at trying to combine both structured and unstructured grids into it. I am looking to use the unstructured grids around the intersections that also have complex curvature. Has anyone had any luck either creating a structured grid at any intersection; like between a wing and the fuselage of the aircraft; or has anyone successfully built a grid that involved structured and unstructured meshes?
Old   January 23, 2007, 12:00
Default Re: combining structured and unstructured grids
Razvan
Hi Shane,
I am currently simulating DLR-F4 wing-body using several hybrid meshes of different densities. The technique I used is exactly the one you are talking about: employ unstructured surface mesh on almost all surfaces and structured in the most difficult regions (wing-body junction, leading and trailing edges). Then apply B-L mesh with 6-10 layers (y+ in wall functions range, over 30 and under 100), and fill the rest of the domain with unstructured tetrahedral mesh. Minimum mesh size for quantitative results is around 2 mill. elements, but for good results you must go over 5 millions (with at least 1 mill. elements in the B-L region only!).
So the answer is: yes, you can make a quite good hybrid grid for aircraft-type geometries, but you must be very careful about mesh quality especially in the B-L region! Drag is particulary sensitive to near-wall mesh quality.
All the best, Razvan
Old   January 23, 2007, 21:57
zxaar
we also use meshes generated in parts. This is my workflow :
[*] make the the meshes in parts such that the mesh on the sharing faces (with other blocks) is exactly same.[*] use tmerge to merge these meshes into one.[*] in fluent, there is a option Grid->Fuse, use this option to fuse the sharing faces of the mesh.[*] save the case[*] import the mesh from this saved case[*] export the final mesh to be used in simulation.
hope this helps , you can avoid the gambit import and export again, for me i do this because this way the mesh is written as a single block, and i prefer that.
[Other] OpenFOAM - structured or unstructured Grids ? thomasduerr OpenFOAM Meshing & Mesh Conversion 22 November 25, 2018 00:18
structured and unstructured grids user Main CFD Forum 6 November 25, 2010 02:14
structured & unstructured grids Samir FLUENT 1 February 7, 2005 01:48
Structured and Unstructured grids Samir FLUENT 0 February 5, 2005 22:21
combined structured and unstructured grids phil FLUENT 0 March 5, 2003 07:00
