Fluent paralell processing in windows XP
Old   January 22, 2007, 21:49
Default Fluent paralell processing in windows XP
JoĆ£o Fernandes
Hi everyone, I need to run Fluent in paralell mode in Windows XP but until now I couldn“t. I started fluent in one computer and started fluent paralell in my own computer with the following command
fluent 2ddp -t2 -pnet -cnf=(hosts file name) -path\\(mycomputername)\c:\fluent.inc\
then Fluent tries to seed the computing nodes and displays the following error message
"Can“t find network path"
Please I would appreciate any help
Thanks in advance,
Best regards
Joćo
Old   January 23, 2007, 00:44
Default Re: Fluent paralell processing in windows XP
Le
You may need Hummingbird connectivity software to run paralell with network.
parallel processing Fluent 6.3.26 ck3 FLUENT 6 October 30, 2013 01:44
Fluent jobs through pbs ibnkureshi FLUENT 5 June 9, 2011 14:43
Parallel Processing on ANSYS FLUENT 12 srr FLUENT 2 April 16, 2011 15:16
Parallel processing problem with Fluent Harish FLUENT 3 February 8, 2011 10:49
Microsoft compiler meangreen Fluent UDF and Scheme Programming 2 July 25, 2009 15:00
