Min value of volume must be positive?
Old   January 20, 2007, 03:08
Default Min value of volume must be positive?
anthro
Hi guys... just need to clarify something... I read onlin that when we check the grid, the minimum value of the volume must be positive.
What does this mean? And what are we actually checking?
Thanks.
Old   January 20, 2007, 05:27
Default Re: Min value of volume must be positive?
Laika
If he minimum cell volume in your mesh is negative, something went terribly wrong! If you do have negative volumes it either is an error in the file of a mesh with extremely distorted cell. Either way, don't continue working with the mesh...
good luck, Laika, still orbiting
Old   January 20, 2007, 07:18
anthro
thanks for the advice.. appreciate it
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
