January 19, 2007, 04:40 |
Two or more materials
can we specify two different materials in fluent, both are not mixing with each other though..
for example, one material is air and the other is ice. Can we specify properties individually for both these volumes? |
January 19, 2007, 08:36 |
Re: Two or more materials
Are you looking at two phase flow. Can you post a picture of your model?
January 19, 2007, 09:31 |
No it isnt two phase flow,
When i give define-->boundary conditions, i highlight the fluid in the dialog box-->set--> then specify the volume modeled as air. this particular way i can specify density, specific heat, enthalpy etc for the air. i want to do the same for ice too, but dont know to apply these values for ice. |
January 22, 2007, 14:16 |
i am not experienced with fluent but plz explain ur model more, i may help you
May 27, 2011, 14:17 |
melting problem with three types of Materials
nhh
Rep Power: 15 |
help
can we specify 3 different materials in fluent, (1 solid and 2 fluid) to simulate a melting & solidification problem. thank's |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Selecting Materials in WB 12.0 plz HELP!! | BrianK | ANSYS | 2 | October 13, 2010 14:28 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 08:56 |
new materials in fluent by mixing other materials | Anna | FLUENT | 0 | January 18, 2009 04:53 |
Reaction help!! | Harry | CFX | 4 | October 30, 2008 10:11 |
