January 19, 2007, 03:27 |
Fluent-AMD-64bit-Linux-Redhat
as far as you know, are there problems in running fluent on Linux Redhat with a Opteron dualcore 64bit processor? Thanks in advance for the help. Cheers, MCB |
January 19, 2007, 04:01 |
Re: Fluent-AMD-64bit-Linux-Redhat
Not sure about Opteron, but if you ask me about Athlon 64 X running 64bit SuSE. Then you better give up.
January 19, 2007, 09:01 |
Hi, If you are licensed user of Fluent, then you would get a list of supported platforms on the following site http://www.fluentusers.com/platform/...=fluent_6.3.26
You need username and password for accessing this page. Depending on it you can decide what platform to be used. |
January 19, 2007, 09:43 |
Thanks Akshay,
this is the answer I was looking for. Regards, MCB |
January 19, 2007, 15:39 |
FWIW, I had some difficulties getting Fluent 6.2 to run under Fedora Core 4 (very similar to Red Hat) and the solution was to simply install ALL packages from the Fedora install disks. It seems that there are sometimes some library compatibility issues, but generally I've had very little trouble making any commercial CFD code (Fluent, CFX, CFDRC, Comet, Icem, Harpoon, Tecplot ....) work with FC4, once ALL packages were installed.
The software vendor's "supported platforms" list is obviously the safe way to go, but if you already have another version of the O/S installed, it's worth trying the CFD install to see if it works before installing another O/S. |
fluent 12.1, batch mode in linux | sakalido | FLUENT | 13 | September 27, 2017 09:55 |
Please help: Fluent 12.1 doesn't run on my AMD X4 630 2.8Ghz PC with Window 7 | andy.eco | FLUENT | 0 | June 14, 2010 18:16 |
Fluent 12.1 on Linux x64 Architecture Issue | fivos | FLUENT | 5 | April 24, 2010 16:19 |
Install Fluent in Linux | L3munoz | FLUENT | 0 | July 21, 2009 15:55 |
Fluent for linux | Patryk | FLUENT | 0 | July 20, 2009 20:04 |
