January 19, 2007, 01:37 |
Mixture A+B and C+D
I have two parallel adjacent channels. Mixture A+B flows in the upper channel and mixture C+D flows in the lower one. But I can't postulate these matetial in the program. I can't set-up the mixture both A+B and C+D, only one mixture appears in the boundary conditions pannel when setting the medium fluid.
How can it be possible? |
January 20, 2007, 01:44 |
Re: Mixture A+B and C+D
Do you have created two Fluid domain in the mesh.( check if two fluids are there in the boundary conditions)
January 21, 2007, 21:14 |
Do you have created two Fluid domain in the mesh. -->Yes. I do it in the specify contimuum types section.
check if two fluids are there in the boundary conditions -->Yes. Two fluids exist and I can determine each material for singel component in material name column. But if I choose species transport option to "ON", the material name colum disappears. |
mixture mass continuity eqn v.s. volumetric mixture continuity eqn | kaifu | ANSYS | 0 | June 9, 2011 09:42 |
mixture mass continuity v.s. volumetric mixture continuity in pressure equation | kaifu | OpenFOAM | 0 | June 9, 2011 09:14 |
Improvement to the update of T_ et al in hMixtureThermoC and hhuMixtureThermoC | richpaj | OpenFOAM Bugs | 2 | October 9, 2008 23:14 |
Variable composition mixture .vs. reacting mixture | Ting Wen | CFX | 0 | January 7, 2008 07:04 |
Burning a CH4-H2 Mixture | Jonathan Lemay | CFX | 2 | November 12, 2007 18:01 |
