solar heat flux through roof
Old   January 16, 2007, 23:55
Default solar heat flux through roof
Tim
I would like to determine how much heat flux will be added to a domain by a solar load only. I have set up simple roof sections in the following ways:
1. Using a zero-thickness wall with Shell Conduction and a supplied thickness, etc.
2. Meshing the actual solid components and assigning the material properties to it.
I am trying to use the solar ray tracing algorithm and am having a hard time figuring out exactly how to set it up.
What surfaces do I pick to participate in solar ray tracing? Only the roof? Everything? The roof and the inlets/outlets?
What post processing value should I use to get the heat flux that will be passed through the roof section. Do I look at "Total Surface Heat Flux" in the "Wall Fluxes" panel? Or is there another value to look at?
I am new to solar calculations and would also like some tips on what one would typically expect for a heat flux with a solar heat flux of 1120 W/m^2 applied to the outside of a roof?
Thanks for any help you can give me!
Old   January 17, 2007, 17:01
Default Re: solar heat flux through roof
Tim
After working with FLUENT, I figured out the problem. If you are going to use a zero-thickness wall with Shell Conduction in FLUENT 6.3.26, you need to use tri/tet cells instead of quad/hex cells.
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 17:25
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 23:22
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 13:20
Solar Heat Flux JoHn@ FLUENT 3 April 1, 2004 11:53
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 06:09
