January 16, 2007, 16:45 |
Errors in parallel computation
I'm trying to set a parallel computation using Fluent 6.3. I use 2 cpu system running under Win 2003. smpi and net connection used. During mesh distribution process the following error always happening:
Updating mesh at time level N... 999999 (..\..\src\mpsystem.c@1123): mpt_read: failed: errno = 10054 The Parallel FLUENT process could not be started. 999999: mpt_read: error: read failed trying to read 4 bytes: Invalid argument what can be the reason for this error? How it could be solved? Thank you |
January 19, 2007, 09:20 |
Re: Errors in parallel computation
Please see if this site servers your purpose http://www.fluentusers.com/support/i...ouble_main.htm
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 16:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 03:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
