UDF PROBLEM
Old   January 16, 2007, 06:23
Default UDF PROBLEM
anant
Hi everybody, I have a 2 D model in which I am using a UDF to give motion to a body(named valve) which inturn is immersed in a control volume. The model is like this. A rectangular object(valve) is placed inside another rectangular control volume. the valve is expected to move up in the Y direction while the flow is on.
Bdry conditions are : inlet--- mass flow inlet outlet---pressure outlet valve--- waLL (with the option moving wall enabled in the dynamic zone panel)
I am modelling it as a dynamic mesh problem and am using the following UDF,
#include "udf.h"
static real v_prev = 0.0;
DEFINE_CG_MOTION(piston, dt, vel, omega, time, dtime) { Thread *t; face_t f; real NV_VEC (A); real force, dv;
/* reset velocities */ NV_S (vel, =, 0.0); NV_S (omega, =, 0.0);
if (!Data_Valid_P ())
return;
/* get the thread pointer for which this motion is defined */ t = DT_THREAD (dt);
/* compute pressure force on body by looping through all faces */ force = 0.0; begin_f_loop (f, t)
F_AREA (A, f, t);
force += F_P (f, t) * NV_MAG (A);
} end_f_loop (f, t)
/* compute change in velocity, i.e., dv = F * dt / mass
velocity update using explicit Euler formula */ dv = dtime * force / 50.0; v_prev += dv; Message ("time = %f, x_vel = %f, force = %f\n", time, v_prev, force);
/* set y-component of velocity */ vel[1] = v_prev; }
I create ONLY the valve as the "Dynamic zone".
After the udf is compiled and the ITERATIONS initiated in an unsteady flow, the vlave DOES'T MOVE. i am doing problem to ascertain the changes in the flow var as the valve moves up in the Y direction. I am unable to identify the error . can some one help .
thanks .
Old   January 16, 2007, 10:36
Default Re: UDF PROBLEM
Venkatesh V
I hope Fluent did correct by not moving the valve. You are assigning v_prev to Y Velocity i.e vel[1].
But in the starting of the code you have initialized v_prev to zero and you have not changed to some number after that.
If your objective is to only move the valve in y direction, no need to use UDF you can jut input these parameters in Dynamic Mesh control panel.
I hope this would help you.
Thanks Venkatesh V
Old   January 17, 2007, 01:15
anant
THANKS VENKATESH FOR A QUICK REPLY,
I am an not very conversant with UDF, however can you please explain how do I go about giving "motion" to the valve by entering the parameters in the Dynamic Mesh control panel. where do I enter the values of the motion ? Is there any tutorial problem rewgarding this ? regards Ananth
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
Problem with my udf july Fluent UDF and Scheme Programming 3 June 20, 2010 07:56
UDF problem mansha goraya FLUENT 0 October 29, 2007 01:31
udf compiling problem akr FLUENT 3 August 22, 2007 08:14
UDF problem chiseung FLUENT 4 January 10, 2002 10:58
