January 16, 2007, 06:11 |
?? Laminar or Turbulent ??
Could anyone help me? I have to determine in my sytem with complicated geometry if the fluid flow is laminar or turbulent? I need to estimate dimensionless numbers Re, Gr, etc ... Could anyone please help me with that? Some UDF or other method? Thank you in advance!!! Best regards, wabik |
January 16, 2007, 11:33 |
Re: ?? Laminar or Turbulent ??
These parameters depends on the physics you are modelling... geometry, velocity, materials etc. This can be used as input (not directly) to fluent, not expected to be calculated by fluent.
But still if required you can compute similar parameters through the udf or custom field function. For example cell reynolds number(this is not th e actual reynolds number in physics. ) can be extracted using a CFF. |
January 17, 2007, 03:03 |
These I know but I have to determine the proper model if it is laminar or turbulent or may by somehow transitional. And if you cold tell me how can I calculate to using two different turbulent models for different materials? I am modelling Czochralski crystal growth. Brgds, w. |
January 18, 2007, 11:44 |
Czochralski crystal growth--OO--i m not aware of it?
But you must be knowing the following things a range of velocity of the fluid you model. the properties of fluid the geometric features of the domain... these can provide you the reynolds number... determine laminar or turbulent if turbulent you can start with std k-e. this will provide good enough results. For more accurate results swith to realizable k-e More complex good models are there, but the are computationally very heavy.. -sujith |
January 19, 2007, 09:11 |
This I know but I wanted to know which model fits the best to reality. So by dimensionless numbers I could do that. p. |
CFX Treatment of Laminar and Turbulent Flows | Jade M | CFX | 18 | September 15, 2022 08:08 |
Laminar vs Turbulent Navier-Stokes | truman | Main CFD Forum | 8 | July 10, 2017 08:20 |
Laminar doesn't converge; Turbulent models do? | Amit | FLUENT | 11 | April 23, 2015 23:55 |
SimpleFoam: Laminar vs. Turbulent Convergence | JasonG | OpenFOAM | 0 | June 2, 2011 09:29 |
Half laminar and turbulent model trying to solve | Andrew Clarke | FLUENT | 5 | May 19, 2008 14:40 |
