Heat conduction between contacting solid materials
Old   January 13, 2007, 20:25
Default Heat conduction between contacting solid materials
Ken Adams
Hi all,
I have a question on modelling heat conduction between two contacting solid materials. When I create the geometry using Gambit, how do I specify that the two entities are contacting?
Thanks a lot,
Ken
Old   January 14, 2007, 16:15
Default Re: Heat conduction between contacting solid mater
Sujith
You have to make a face separating the two solids. You can assign this interior common face as an interior boundary. The two solids should be 2 separate volumes and two different solid zones should be assigned to each volume. This makes an assumption that the contact is a perfect contact.
Old   January 14, 2007, 19:48
Ken Adams
Thank you for answering my question. But if I create two blocks, do I put them together by "Unite" or by "Connect" contacting faces? Do those two operations result in a face with the same properties? Thanks.
Old   January 15, 2007, 11:38
Sujith
If you unite two adjacent volumes sharing a common face, the face will be merged in and deleted, resulting only one volume.
You have to have the two volumes connected, not united.
You can try , creating one volume, then splitting the volume into two using a face (create a large face and move it to required position) , with the connected option turned on. This will create two connected volumes. Now yuo can define the two volumes, as different fluids and do the simulation.
Old   January 15, 2007, 12:13
Ken Adams
Thank you.
Old   January 18, 2007, 19:14
Saim
Sujith,
You mentioned that "Now yuo can define the two volumes, as different fluids and do the simulation..."
Here,I am very interested in how to define different fluids (say, air and oil) for different volumes in Fluent solver environment. Does Fluent have this capability to perform this kind of simulation task with two fluids in differnt zones?
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
Heat conduction through solid rib in periodic duct Dieter Fauconnier FLUENT 0 October 7, 2004 09:22
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
