about wind turbine power prediction with cfd
Old   January 11, 2007, 07:36
Default about wind turbine power prediction with cfd
windman
I prepared my model for a case of 3 bladed HAWT. Using periodicity, ı modeled the 1/3 of the flow domain.Calculation coverges successfuly with constant angular velocity and varying wind velocities.
FLUENT gives unreal power values where I get several Cp values exceeding 1. My question is, supposing the modeling, meshing and solving stages are correct, is this a possible situation in FLUENT? Am I choosing unrealistic values? Turbine diameter is 40 m and wind velocities are: 4, 5, 8, 10, 20 m/s with fluid domain's constant angular velocity of w=2 rad/s.
Thank you for your valuable time...
Old   January 11, 2007, 07:41
Default Re: about wind turbine power prediction with cfd
windman
By the way I use Cp = Pcfd/Pwind where
Pwind = 0.5*rho*A*Vwind^3
Wind Turbine - Rotation of the Baldes moonomid CFX 32 March 18, 2016 20:34
Ducted wind turbine (BC for the shroud) Pepita CFX 4 June 29, 2013 08:09
Wind Power Frank Grassi FLUENT 0 October 12, 2007 12:20
Wind turbine simulation Saturn FLUENT 1 June 16, 2006 03:12
CFD for fans & blower housings David Carroll Main CFD Forum 8 August 24, 2000 18:25
