Rotate mesh
Old   January 9, 2007, 15:11
Default Rotate mesh
Bo
Hi, I created a two-dimensional mesh in gambit2.0. However, the model is actually perpedicular to the one I created. So I need to rotate the mesh. Is there any command in gambit that can rotate your mesh 90 degrees? I don't have too much experience with gambit and I did a search and could not find in their help file. Thanks.
Old   January 10, 2007, 17:02
Default Re: Rotate mesh
Meng
You can use the "Tmerge" tool in Fluent Package. Meng
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[snappyHexMesh] non-smooth mesh Svensson OpenFOAM Meshing & Mesh Conversion 11 January 18, 2012 10:13
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
