Fan Perfomance Test on Fluent
Old   January 8, 2007, 11:19
Default Fan Perfomance Test on Fluent
abhinit
Hi i am doing fan performance test. My fan is 460mm Dia. I want to know what should be my domain size and about how much portion i should make rotating zone?
Also what should be my boundary condition.
Old   January 8, 2007, 13:39
Default Re: Fan Perfomance Test on Fluent
Ralf Schmidt
Hi!
If you want to compare your results to experiments (what I would do always at least for one case...) your domain and your BC have to be close to the situation, were the experiments were made.
That is, for a fan test place, with free blow out and free blow in: a pressure outlet and a pressure inlet condition. The piping system is your domian - thats basically it.
I dont know about moving mesh... sorry...
Ralf
Axial fan test rig ramesh FLUENT 5 August 10, 2014 06:49
Fluent setup to determine fan performance afaik FLUENT 5 August 1, 2014 05:27
fan function in fluent vikasmeche FLUENT 0 June 12, 2009 04:37
Stability test using fluent possible or ???? Novice FLUENT 0 July 25, 2008 06:59
Tracer Test on FLUENT Priyal Main CFD Forum 1 August 27, 1999 12:13
