Turbulent heat transfer
Old   January 8, 2007, 08:07
Default Turbulent heat transfer
Hugo
Hi.
I'm stuggling to get correct heat transfer using the k-e model.
I'm trying to model heat transfer from fluid to a wall, using the k-e model, for a cylinder in a cross-flow. I've got y+ values in the range 30-300 as the good book suggests, but still the Nussult numbers are ten times higher than those suggested by an experimental correlation (Churchill & Bernstein, J Heat Trans. 99:300). Is there another criterion that I have to meet to make sure heat transfer is coorect? Anyone had similar experience? HELP!!!
Thanks, Hugo.
Old   January 8, 2007, 11:57
Default Re: Turbulent heat transfer
Ralf Schmidt
Hi!
Are your reference values set correctly???
Ralf
Old   January 11, 2007, 10:34
Hugo
Yes, got it wrapped up - should have been calculating my own Nusselt numbers, not relying on the values that Fluent was putting out. Thanks, Hugh.
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Heat transfer BC at wall- why need wall thickness? Julie FLUENT 7 February 3, 2012 22:41
empirical formula on turbulent heat transfer zhhuang FLUENT 0 March 3, 2003 01:34
Heat Transfer Coeff. at Heat Flux Boundary Rushyen CFX 6 January 18, 2001 06:09
Heat transfer coefficent in turbulent flow Ola Lindgren Main CFD Forum 2 November 17, 1998 06:49
