January 8, 2007, 01:01 |
solution control
hi everyone changing the under relaxation factor when iterating is producing any change in result. thanks in advance
January 8, 2007, 08:10 |
Re: solution control
Under-relaxation factor shouldn't change the final result, only how quickly you get there, and if the path towards the solution is stable. Hugh.
January 16, 2007, 23:27 |
thank you
Exact solution of Burgers equation | mcaro | Main CFD Forum | 3 | January 25, 2011 07:46 |
Steady solution from Transient simulations | wawa | FLUENT | 2 | November 9, 2010 18:44 |
How to get the solution of last time step? | lzgwhy | Fluent UDF and Scheme Programming | 0 | September 15, 2010 23:23 |
Integration along a line during solution | DaRumpel | CFX | 16 | September 2, 2010 12:17 |
Solution control - discretization | Aireen | FLUENT | 16 | May 7, 2006 07:38 |
