simulating coanda effect
Old   January 3, 2007, 16:52
Default simulating coanda effect
alfin
hi
i would like to know whether anybody has simulated coanda effect using fluent.
Old   January 4, 2007, 01:59
Default Re: simulating coanda effect
Rajesh
I did.....
Old   January 4, 2007, 12:04
alfin
hi
i would like to know wht turbulence model you used. could you please help me ouyt with that
ALFIN
Old   January 4, 2007, 22:06
Rajesh
Dear Alfin,
I tried to simulate the flow field in a Coanda ejector where a primary jet flowing over a Coanda surafce drags the secondary flow into the ejector. I wanted to calcualte the sceondary mass flow rate and the length at which both the flows are completely mixed. I used standard k-E model and got reasonable results.. What's the problem you are trying? and what exactly do you what to know?
regards, rajesh
Old   January 5, 2007, 12:20
alfin
hi rajesh
i want to simulate the following
There is a foil (say a very thin strip of aluminium in the form of a cantilever beam)
there is a hindrance above the foil at a reasonable diatance when i blow the air above the hindrance the air removes the air between the hindrance and the foil due to coanda effect
this makes the foil bend upwards due to pressure difference above and below the foil
i just wanted to know the pressure plot between the hindrance and the foil
i hope i made myself clear
Old   January 5, 2007, 22:21
Rajesh
I think you can do this problem in fluent quite easily. You can use segregated/coupled solver depending on the Mach number of the airflow (I presume that the Mach number is very low..if its lower that 0.3, then you can use the segregated solver) Use pressure inlet for the incoming air and pressure outlet for all other boundaries with atmospheric pressure values (...again depending on your air speed). If you have high air speeds, you can impose atmospheric boundary conditons by extendng your domain.. You can define a line in between the hindrance and the airfoil and plot the static pressure there. Standard K-E (wall functions) is suffient for getting reasonable results. Try with small no of grids first(..may be 5000 or 6000). That will give you an idea how the solution progresses. Then try increasing the grids till the static pressure plot doesn't change with number of grids.
hope this helps..
all the best Rajesh
Old   January 8, 2007, 12:11
alfin
hi rajesh
thanks for your help, i am doing it that way still i haveto refine .....
get in touch with you soon
ALFIN
Coanda Effect to produce lift. Austin Main CFD Forum 4 May 23, 2011 08:51
Coanda ejectors Rajesh FLUENT 5 December 12, 2010 11:02
Coanda effect, condensation on sphere technophobe Main CFD Forum 4 February 17, 2010 11:04
Coanda effect nacaairfoil Main CFD Forum 11 October 23, 2009 08:11
coanda effect Craig Robbins Main CFD Forum 5 September 9, 1998 00:21
