Dear Friends,
Any body can tell me, Fluent can be used to get the pressure and temperature distribution in the rocket exhaust plume. bye with regards sisir |
Sisir, I can't see any reason not to do so If you model your problem properly. Jim
Thanks Jim Clancy for your response. I am an electrical engineer so I have lots of difficulties and doubts. Still I am trying to do using Fluent. Pls send me ur email id for further contact. My email id: sisir_in@rediffmail.com
bye.... sisir |
pipin
Rep Power: 17 ![]() |
I wanted to disinterring this post to tell you about my problem. I'm supposed to calculate the concentration of a species in a jet nozzle. Literature show me the peak temperature (reburning zone) far beyond the FLUENT calculation and mass fraction of OH for example does not change in the reburning zone ... Solver is pressure-based, I'm in k-e standard (or realizable) and species transport (12 species and 17 reversibles reactions) with laminar finite rate model. I like to know if you have some advice to help me see more clearly?! Thanks |
pipin
i think it's the fault of the unit of the rate coefficient (Arrhenius)
in litterature, i have the activation energy in cal/mol and R in cal/mol.K whereas FLUENT wants E in J/kgmol... Does anyone would have any idea? |
Nikolopoulos Aristeidis
Rep Power: 15 ![]() |
Ok, you should double check the units!!!
Check the order of the reaction as well! Are you sure that laminar finite rate applies in your model???? If not try the finite rate/ eddy dissipation model However, reacting flows are highly difficult problems as far as convergence with experimental data is concerned. There are more sophisticated models for homogeneous reactions (chemkin tables...) but first check the ordinary ones. |
pipin
Thank you for your answer.
I checked the units and i found several mistakes... Now the reaction are simulated but no in the same range... I explain, i've reaction between OH and O, HCL for example and they have to caused a rise of temperature in a specific part of domain... but i'have the maximum of concentration of the OH species but not in temperature... Which track should i follow in your opinion? My model : PBNS, standard Ke, Non equilibrium with Viscous heating, and laminar finite rate. |
#9 | |
PURUSHOTHAMAN
Probelm with supersonic exhaust to ambient | newj | CFX | 2 | August 9, 2012 18:01 |
Modeling intake and exhaust in ICE | Alexvader | OpenFOAM | 2 | September 26, 2011 13:50 |
modeling an exhaust flow | foxx | FLUENT | 2 | December 4, 2008 11:32 |
Modeling Flow/Saturation/Absorption in Fibers | Gene Dougherty | Main CFD Forum | 0 | June 6, 2003 14:49 |
CFD Modeling of Two-phase Flow in Small Dia.Tubes | Eric Poindexter | Main CFD Forum | 2 | September 22, 2000 09:21 |
