Gambit error: cannot select faces and volumes
Old   December 15, 2006, 08:39
Default Gambit error: cannot select faces and volumes
smillerhh
Although there are faces and volumes in my Gambit model, neither faces nor volumes can be selected with the mouse (both select mode and shift-left mouse button don't work). Edges and vertices work as expected. All the other mouse actions like moving and zooming work ok. What to do? Saving and reloading doesn't cure the problem. It seems to be inherent to my model.
Old   December 15, 2006, 10:07
Default Re: Gambit error: cannot select faces and volumes
Jason
It could be that the faces and volumes were turned off. Click on the display attributes button (it's towards the bottom of the screen... looks like a read rectangle with check boxes). Select the volume and the faces option, and make sure the drop down says select all. Then towards the bottom make sure the visibile is selected and the option is on.
Hope this helps, and good luck, Jason
copying volumes in Gambit Naghman Khan FLUENT 11 April 12, 2013 06:20
Splitting Volumes with Faces in Gambit An Modh Coinniolach FLUENT 7 May 2, 2011 23:27
merging faces on a copied volumes kunal FLUENT 0 March 20, 2008 07:50
Alternate method to subtracting volumes? Daniel Lee FLUENT 2 July 25, 2005 09:58
Ghosts Volumes on Gambit ?!! help please Andres D. Ortiz FLUENT 0 October 7, 2001 20:17
